Hang on tempdll.dll
Posted: Tue Sep 28, 2010 7:32 pm
by flowstone
When I try to make a standalone version of my schematic, flowstone hangs while attempting to move or copy tempdll.dll--often crashing the entire application. However, it seems to work normally on a couple of the example schematics. Any suggestions? Thanks in advance for your help!
Clayton
Re: Hang on tempdll.dll
Posted: Wed Sep 29, 2010 10:20 am
by admin
This is when you have FlowStone FREE AND FlowStone Pro/Enterprise installed on the same machine.
If you installed FlowStone FREE last the regestry is pointing to theFlowStone FREE folder for the make EXE.
Simple solution, you can have both versions running, but make sure that FlowStone Pro was the last version you installed.
ie. re-install FS Pro
