Switch FLowstone versions with BAT file ?
Been searching around for this file posted a long while back. Since the harddrive that held this file died,
having to go on memory ...
I believe it was a BAT file, where by, changing the name of the file would allow access to different versions
of Flowstone that are installed.
Does anyone recall this 'script', and maybe has a copy to share ?
Thanks for any help 8-)
Walter Sommerfeld
Re: Switch FLowstone versions with BAT file ?
Post by Walter Sommerfeld »
sorry i'm seldom here active...
Yesterday i missed searching inside archives for u... but now i found something...
But i think these are my own from 2007 ;)
Maybe u can modify these...
Even better include the "C:\Users\USERNAME\AppData\Roaming\FlowStone\" folder?!
Keep on doing!
Walter
SM_Start_bat.zip
some old bacth files i found...
(2.08 KiB) Downloaded 589 times
Walter Sommerfeld wrote:Hi,
Keep on doing!
Walter
Hi Walter ... Thanks !
This looks to be the BATs I was trying to find. As I recall, the actual filename was used to determine which
version of FlowStone to activate.
Thank again 8-)
