deleted primitives, modules not removed?
Can someone please verify if this bug is also in FlowStone 3.0.0?
http://synthmaker.co.uk/forum/viewtopic ... 043#p90043
Re: deleted primitives, modules not removed?
Yes it is, but it's not quite as you think it is. The bug is in the statistics dialog - it's counting components that it shouldn't, namely those created behind the scenes for serving up the properties. These get created and deleted on the fly. The stats shouldn't include these.
So don't worry, there are no components being left behind after deletion.
We will correct the bug in the stats that incorrectly counts property item components in the first update.
Cool, cheers!
Has this been fixed in 3.0.1 please? I do not see it listed in the release notes: http://www.dsprobotics.com/versions.htmlsupport wrote:Yes it is, but it's not quite as you think it is. The bug is in the statistics dialog - it's counting components that it shouldn't, namely those created behind the scenes for serving up the properties. These get created and deleted on the fly. The stats shouldn't include these.
Yes, it's under fixes:
Fixed a bug with the statistics calculating incorrectly when property panels are being used
There it is! Cheers MyCo.MyCo wrote:Yes, it's under fixes:Fixed a bug with the statistics calculating incorrectly when property panels are being used
