Some help with Trog's Super Text Box
Hi..Greetings from Down Under
I need some help. My ruby skills aren't good enough.
Trog has explained the code really well in this schematic, but I can't work it out
All I need is Sort 'trigger" for the QTY Column.The problem is how to make all the rows
sort the same way according to the values in the QTY Column...
Re: Some help with Trog's Super Text Box
I'm not sure I understood. Anyway, here's an external trigger, that sorts based on qty. The first time it's sorting low to high, the second time high to low.
If you wanted to know the general technique, it's :sort_by! of the array class.
array = [
["John", "Doe", 20],
["Jane", "Doe", 18],
["Annie", "Thing", 34]
array.sort_by! { |obj| obj[2] }
##sorts the array of arrays based on the contents of their third items, here the age number##- Attachments
- Super Text Box Problem (tula).fsm
- (11.91 KiB) Downloaded 833 times
billv wrote::D Awesome..works perfect..thanks tulamide
You're welcome
I just want to take the opportunity to point out, that this was only possible, because Trog, although having a large code base, has it structured very well, so that I could relatively easy follow his thoughts and layout of the code. That was even more important than the documentation!
Most people neglect that. Please don't. At one point sooner or later, you will need help with your own code. Make sure it is easily readable (for someone who knows Ruby). Stick to the conventions and styles, the Ruby community agreed on, and it will be so much easier to help you.
https://rubystyle.guide/
