Configurator from xxx.cfg File
Posted: Mon Jul 31, 2017 4:31 pm
by Pali64
Hello there
here is a useful tool to made a selfconfigurating for a FlowStone Application
in the Example if 3 different Box (2x 1 line encoder & 1 x 5 Line encoder)
The 1st Box:
it get the entry indicator [Adjust] after the 1st (:) in Example schow
The 2nd Box:
It extract 5 different parameters in same way as [xxxx] above market
The 3rd Box:
search the last Marker in Example [UseTXT] and get it up to end of File this useful for place Informations in the xxx.cfg File
in the Window is the (Test.cfg) File as an Examplebox
to use it copy the Window to the Editor and save it to (Test.cfg)
"sorry .cfg file as atachement here not alowed" :cry:
its Useful for Configuration of Programs from a cfg file...
Hope you can use it and understand to use :)
Greeting Pali64
