String Step sequencer
Pali64
Post by Pali64 »
Hello members
another Helpful Tool ;)
a 8 Step Stringsequencer with a Syncable Stringoutput
For a better understanding,
If usefull for send Initialstrings to MIDI or Other Interface it used more as one Initialstring to work.
The module [Sequencer.fsm] was created under "FlowStone 3.0.8"
I'll later add more tools as soon as they run error-free
Greetings Pali64
Sequencer.fsm
Programable 1 ~ 8 Step syncable Stringsequencer
(4.82 KiB) Downloaded 1241 times
We made Keyboard and Synthesizer for you
so all Poaple can kommunicate with a Language to all poaple understand
Music is the nicest work in World ;)
Re: String Step sequencer
Pali64 wrote:The module [Sequencer.fsm] was created under "FlowStone 3.0.8"
The upload won't open in 3.08. It was presumably made in 3.09...
Pali64
Post by Pali64 »
Hello Spogg
Spogg wrote:.....was presumably made in 3.09...
Sorry i work with 4 Different FlowStone Versions to test works wit all. ;)
So i was wrong attachement now i corekt it... :D :mrgreen:
Thx for you Test :D ....Live long and peacefully.... ,\\//
Greeting Pali64
Sequencera.fsm
Version 3.09
(4.82 KiB) Downloaded 1189 times
Sequencer.fsm
Version 3.08
(4.79 KiB) Downloaded 1227 times
Yes that one opens :D
I would like to see it with some inputs and outputs to better visualise its function.
I'm not complaining but I think it always helps to see a new module demonstrated at least in a very basic way...
lalalandsynth
Post by lalalandsynth »
This looks interesting, shame I have no idea what it does ;)
Pali64
Post by Pali64 »
Hello all
A other Version of this Sequencer
dos not use a external string input. it use a 8 Line entry mask for the 8 Strings, the No. of Pulse as Feedback.
and No. of Steps (1~9 = Last step is Exit and 1st Step is to Activate so 9 for 8 entries used)
The Checkbox on all Lines is to send a CR after string or not....
The module [8StepSequ.fsm] was created under "FlowStone 3.0.8"
Greeting Pali64
8StepSequ.fsm
module] was created under "FlowStone 3.0.8"
(4.89 KiB) Downloaded 1157 times
BobF
Post by BobF »
Thanks Pali64,
but like Spogg said, we really need some input/outputs to fully appreciate this.
Keep up the great work, BobF.....
Pali64
Post by Pali64 »
Hello BobF &Spogg & all others
BobF wrote:T... need some input/outputs to fully appreciate this.
Here is a Picture to i use this sequencer
A practic to use this String Step sequencer
BobF
Post by BobF »
Hello Pali64,
Thanks for the picture, but I am curious, why not just supply the fsm?
Cheers, BobF......
Pali64
Post by Pali64 »
Hello BobF
Your Question:
BobF wrote:..... but I am curious, why not just supply the fsm?......
My answer:
The program in which I use it is very comprehensive and has also "Bug's" it would be nonsensical such a mamut program to disassemble to show only a few examples;) unfortunately, I am currently missing the time to "just as times "To make an application to show it as an example ... SORRY ...
But I would like to try it out later, if I have still other modules tested and you to the place of post here ...
Cheers and have a nice time ....
