X10 Home Automation PIR Test
In this example FlowStone sends out the X10 commands to the Marmitek CM15 Pro USB X10 Controller to turn a simple lamp on and off from a wireless Passive Infrared sensor (PIR) (Marmitek MS13E Motion Detector).
The PIR address is set to A1 and the lamp address is set to A2
Any movement detected by the PIR switches the lamp on for 10 seconds!
- X10 PIR Test.fsm
- X10 PIR Test
- (12.56 KiB) Downloaded 4988 times
