Mirror /Flip Gui ?
lalalandsynth
Mirror /Flip Gui ?
Post by lalalandsynth »
Is there a way to mirror/flip a gui , I can rotate it but that does not have the same result.
Sub question :
Actually I might solve this particular problem if I could invert Array values , possibly ?
Thanks.
Re: Mirror /Flip Gui ?
I wouldn't know why you need to mirror a whole GUI, but in general you can mirror/flip bitmaps by passing negative width or height values. So, for the whole GUI you'd need to invert the values of each bitmap, and mirror the positions as well. This only works for bitmaps, of course, if there are runtime graphics, you'd need to alter the individual RubyEdits.
lalalandsynth
Yep , seeing that I am not a programmer at all I was thinking if I could invert the output from an array ?
That way I would invert the "Gui", as it were ...I think ?
Here is why I want to rotate and mirror the GUI , or parts of the gui , namely the Envelope.
I can invert the envelope output , so rather then a fully open envelope having max volume it now has min volume, lets say you like the envelope but want it inverted for a variation on what you are processing.
Original envelope - I have a invert button to invert and offset the phase so it is only unipolar like the original.
Basically achieving what I want , but the envelope does not represent that.
Invert pre.jpg (59.15 KiB) Viewed 10169 times
Then I can rotate the GUI , but it still does not represent the envelope inversion , although , If I could work on the Ruby code or array output , this would be a cool function.
Rotate Gui.jpg (53.85 KiB) Viewed 10169 times
This is essentially what I want to achieve , Rotate and Mirror , and now it represents an inversion.
Rotate Mirror Gui.jpg (54.5 KiB) Viewed 10169 times
This is all just a workaround , If I could work on the output array from the Line editor it would make everything simpler I am sure.
