Simple Animation
Posted: Mon Mar 27, 2017 1:00 am
by aronb
I am trying to make a simple animation, but using the schedule method.
I need to see the object in the view window, and also get the outputs from the Ruby module at a regular time - say 1 to 50 times a second. In this example the dot should simply move diagonally down fro the top left to the bottom right... Of course with other equations I could make the dot move in a circle, or in a line, etc.
Can someone take a look at my schematic please and see what I am doing wrong :? ?
Animation_Test.fsm
Not Working
(137.93 KiB) Downloaded 886 times
Thank you for any help or guidance you can give.
Aron
Re: Simple Animation
Posted: Mon Mar 27, 2017 5:39 am
by aronb
I think I figured it out. :shock:
Animation_Test_ Working.fsm
Simple Timed Animation
(199.88 KiB) Downloaded 1006 times
Here is a simple timed animation system. Put whatever you want in the animate section, calculate the steps based on the position.
Of course you could also use this for a super slow oscillator too ;)
Aron
