Drawing GUI Out of the plugin
Hi, I am trying to draw a GUI but out of the plugin interface. I dont know if you are understanding me
But here is an example:
As you can see, the plugin is massive and the red part is drawn out of the plugin (acting like a pop-up)... Is this possible to make in FlowStone?? Thanks (and sorry for my bad english)
Re: Drawing GUI Out of the plugin
Hi Wassaka!
Look this...
- Plug-in About.fsm
- (8.23 KiB) Downloaded 1003 times
this is not possible, you only have one fixed sized main window for your plugin..
the only thing you can do is to call windows popup windows for warnings or info..
yes its possible. if your image/module that you hide is different size than the main plugin you can shill show/hide it with the view
Surely this can only be achieved if the popup window is smaller than the main VST plugin window...?
yes you can create a window inside the plugin, also move it around, but only insidse the plugin window!
Its not possible to create a window outside of the plugin window!
(except windows system specific message boxes, which you can call with the win32api)
