Preset manager There you use folder
djbrynte
Post by djbrynte »
Hi every one i wonder if some one could help me make a preset manager There you put the preset banks in a folder beside vst There you can select preset bank in a list box or something. Lets say u put New banks inside this Map then they should show up in that list.
MichaelBenjamin
Re: Preset manager There you use folder
Post by MichaelBenjamin »
Last edited by MichaelBenjamin on Mon Sep 21, 2020 11:02 am, edited 1 time in total.
Something I had to do with a project awhile back ...
Something called the 'Marshall' format [i think that's what it was called].
TROG is the one that pointed me how to do this ... with RUBY.
I've long forgotten the details ... but it might show up in a search .... or was that back in the SM daze ... :|
kortezzzz
Post by kortezzzz »
Here are 2 examples using 2 different methods for fast saved preset banks switching. Bare in mind that you'll have to locate the target preset bank folder first to make it work properly. The first method is radio buttons menu based on Trog's Ruby selector (including scrolling feature). Once you save a bank, it will instantly appear in the menu. Saving any additional bank will switch to that new bank after saving. Same operation method is applied to the second example, which is simple drop list menu.
(PRESET BANK MAKING EXAMPLE).fsm
(231.55 KiB) Downloaded 1118 times
kortezzzz
Post by kortezzzz »
(PRESET BANK MAKING EXAMPLE 2 WITH DROPLIST).fsm
(224.04 KiB) Downloaded 1189 times
djbrynte
Post by djbrynte »
Will check this out soon kortezzz
djbrynte
Post by djbrynte »
thanx alot kortezzz exactually what i was looking for.
