Graphing Data
Eugene529
Graphing Data
Post by Eugene529 »
Is there a way to create x,y data graphs (Floating point numbers)?
support
Re: Graphing Data
Post by support »
There is a Graph Module in FlowStone that takes an array of floats and draws a graph. If you look at the FFT Module you will see how it is done.
eg.
Graph clip.png (92.82 KiB) Viewed 18063 times
Graph.fsm
(3.41 KiB) Downloaded 1106 times
Eugene529
Re: Graphing Data
Post by Eugene529 »
These displays appear to output a graph of a floating point variable and time. Is there a way to graph two independent variables?
Eugene529
Re: Graphing Data
Post by Eugene529 »
I would guess that the function I need to experiment with is the Point Array Lines. I this correct?
support
Re: Graphing Data
Post by support »
Yes correct but now we have Ruby there is a better way:
Ruby Graph clip.png (55.1 KiB) Viewed 18064 times
Ruby Graph.fsm
(1.08 KiB) Downloaded 1147 times
aronb
Re: Graphing Data
Post by aronb »
I need to graph the output of 2 oscillators (think lissajous)...
I could use the Point Array Lines but it auto scales the graph... :evil:
Please, how do you stop it from auto scaling?
I want the graph to be scaled at -1 to 1 on both axis regardless of what I input... as may signal (pattern) gets small I want to see it get small NOT have the graph automatically "gain up".
Very frustrating.
Aron
XY_Scope.fsm
XY_Scope Schematic
(833 Bytes) Downloaded 1039 times
Jay
Re: Graphing Data
Post by Jay »
Do you want it to be scaled in size comparible to the volume/level of the signals?
like this?
XY_Scope-1.fsm
(32.04 KiB) Downloaded 1052 times
aronb
Re: Graphing Data
Post by aronb »
Well I guess... this works to some extent.
The use of the envelope to calculate the area based on the x signal (or y or both) makes it work for some frequency. As the frequency is lowered the scope becomes jittery.
Thanks for the fix, it is quite ingenious!
I was hoping that a version existed that did not "autoscale" and did not need to be "tricked".
I included an offset to show the remaining issue...
We just need a good XY Display with color capability... like an old Vector Monitor - think old school arcade vector games. Or again the Point Array Lines module WITHOUT "autoscale"... I can't even think why you would want a module to falsely add gain to something you want to display in the first place.
Thanks for the help,
Aron
XY_Scope_2.fsm
(39.96 KiB) Downloaded 1047 times
