Separators in menus
az-terisk
Separators in menus
Post by az-terisk »
Hi gang !
How can i add separators in the menus, please ? Like Adam Szabo's Viper main menu : https://image.noelshack.com/fichiers/2020/32/5/1596834020-capture.png
Thanks !
adamszabo
Re: Separators in menus
Post by adamszabo »
That is possible in the alpha versions only
az-terisk
Post by az-terisk »
adamszabo wrote:That is possible in the alpha versions only
Hello Adam, i'm an user of Alpha version ! :)
adamszabo
Post by adamszabo »
Then you can write this string in the dropdown list to create a line between item 3 and 4: "Item1, Item2, Item3, -----, Item4" and you will get the separator. Just watch out because the separator still counts as a value, but you cannot click on it. So like this:
Item1 will output 0
Item2 will output 1
Item3 will output 2
(the separator will output 3 but you cannot select it)
Item4 will output 4
az-terisk
Post by az-terisk »
Many thanks to you Adam, i will made it ! :)
