Page 1 of 4
Missing keys in cords
Posted: Thu Jul 02, 2020 6:46 pm
by tektoog
Hey all, here is a bug I've spotted in the latest Alpha, but also in 3.06 and 3.08: When playing a 3 keys chord, it all goes well with octave 0, but only 2 keys work with higher octaves. I don't know if this has already been mentioned, but now it's done
I made a video to demonstrate it
- test 02.rar
- Missing keys in chord
- (1.32 MiB) Downloaded 1273 times
Is this bug confirmed or is it just me?
Re: Missing keys in cords
Posted: Thu Jul 02, 2020 8:03 pm
by deraudrl
Can't look at your RAR file yet...I
knew there was something I forgot to install when I set up this laptop last month.
Pending getting it opened, and so going only from your description, I'd only note that (1) 3.0.6 has been out 8 years or so, (2) that's a
really obvious bug, and (3) it's a bad enough bug to make FS essentially useless. The idea that no one has encountered it before is so improbable that it makes me think, yeah, it's just you.
Then again, I could be wrong.
Posted: Thu Jul 02, 2020 8:13 pm
by deraudrl
Followup: I looked at the video on Slack, where it's just an AVI file. Problem is, there's no sound, and I have no idea what I'm supposed to be seeing.
Can't you just post up an example 3.0.6 FSM here that demonstrates the bug?
Posted: Thu Jul 02, 2020 8:20 pm
by tektoog
deraudrl wrote:it's a bad enough bug to make FS essentially useless
I know... but it does that to me even with the example synth of SM... No coding of mine in that!!!
And because I really focused on mono-line step-sequencing, and samplers (no polyphony) I've never really paid more attention than that to it...
But now that I'm working on a synth with no step sequencer in it... I'm like what the...
deraudrl wrote: there's no sound
It might be on your side... I do have sound here on the video
deraudrl wrote:Can't you just post up an example 3.0.6 FSM here that demonstrates the bug?
If you have SM, it does it to me with the example synth
(even played with the latest Alpha!)
Posted: Thu Jul 02, 2020 11:42 pm
by deraudrl
Ok, just tried the "Example Synth.fsm" that came with 3.0.6: 3-note (and 4-note) chords work fine in every octave my MIDI keyboard will transpose to.
Dunno what to tell ya.
Posted: Thu Jul 02, 2020 11:55 pm
by tektoog
Ok thanks for testing
Have you tried without transpose? just by going up octaves on the keyboard itself, physically?
Also does it work with the PC keyboard? that's what I use, in fact... like chord with x/v/n no problem...
but r/y/i doesn't... (oops i have an french keyboard
) it's the same placement/location for these letters with qwerty, isn't it?
but you saw my vid, didn't you?(with sound I hope
) It doesn't work for me... why? and it does the same with my Nano key controller...
Posted: Fri Jul 03, 2020 3:07 am
by deraudrl
tektoog wrote:Ok thanks for testing
I have a 4-octave M-Audio keyboard...I just used the transpose to get the two octaves at the top and bottom.
tektoog wrote:Also does it work with the PC keyboard? that's what I use, in fact... like chord with x/v/n no problem...
Didn't try that, don't normally use it. But I would not be surprised if simultaneous-hit chords don't work well on a PC keyboard: it's not really what they're designed to handle. In any case, I would expect variances between different keyboards/drivers/etc anyway.
tektoog wrote:but you saw my vid, didn't you?(with sound I hope
Looked at it on another machine using VLC. The good news is, I heard sound, the bad news is, the video was rotated 90 degrees (to vertical) and smashed almost flat. But what I heard appeared to match the keys being lit up in all cases, take of that what you will.
Posted: Fri Jul 03, 2020 3:23 am
by tektoog
deraudrl wrote:I heard sound, the bad news is, the video was rotated 90 degrees
Haaaa good
I think you have to tweak your VLC, I use it here also and it plays right
deraudrl wrote:what I heard appeared to match the keys being lit up in all cases
No it does not... only when keys are hit individually, or in chord with Octave 0 - x/v/n
the octave above plays well individual keys, but not the chord r/y/i... there should always be 1 or 3 keys playing and if you look closely at some points there are only 2...that's where the bug is...
deraudrl wrote:Didn't try that, don't normally use it
Could you try it, please? to confirm or not...
And I also tried the example synth of 3.06 version, the one with arpeggiator, if I press 3 keys on Octave 1 (keys r/y/i) I have no sound at all...
Thanks for your time
Posted: Fri Jul 03, 2020 3:36 am
by nix
I can confirm the bug
-szx ...x doesn't sound here
when I create MIDI in FS there is no such issue, I am always using my code to create MIDI
I'll just try some simple analytics on the MDI coming out of the typing keyboard
Posted: Fri Jul 03, 2020 3:49 am
by deraudrl
tektoog wrote:Could you try it, please? to confirm or not...
Ok, on my Logitech K200 QWERTY-layout keyboard, I (sort of) see the "bug", intermittently and with different symptoms than yours. In my case the 'qwer' row usually works more consistently than the 'zxcv' row, but sometimes both work and then a few seconds later neither will.
Be that as it may, I'm not sure it counts as a "bug". Quite frankly, I'm a bit surprised playing chords on a PC keyboard works at
all.
