Preset manager causing crash
Recently, I have found that Preset Manager save causes Flowstone to crash. This occurs even a trivial schematic with only DSin and DSout. In this case, there are no preset variables to save, but the same problem occurs no matter how many or how few preset variables there are.
The errorlog.txt states: "Access Violation (0xc0000005) in module ntdll.dll at 001b:7c919af2". I see the same behavior with both XP Pro SP3 and Win 7 SP1. With Win 7, the errorlog message is slightly different: "Access Violation (0xc0000005) in module ntdll.dll at 0023:772e8dc9"
I believe the problem to coincide with Flowstone 2--it has worked fine for many months up until recently.
Any suggestions you can provide are greatly appreciated. Thanks!
Clayton
Clayton
- preset manager test.fsm
- (8.8 KiB) Downloaded 1088 times
Re: Preset manager causing crash
Not seen that here, I'll check it out over the weekend.
