->Analog Saturation<-
My Projects associated with an experimental simulation of analog saturation, I'll refine it in the future, and to improve as much as possible,
waiting for your comments!
- Analog Saturation.fsm
- (350.18 KiB) Downloaded 1333 times
Re: ->Analog Saturation<-
DigiTonix wrote:My Projects associated with an experimental simulation of analog saturation, I'll refine it in the future, and to improve as much as possible,
Looks are really good and I love the on/off button and the flickering logo!
I can make changes to the sound but I'm not sure what all the controls actually influence! Any chance could you give a brief explanation to a stupid old Vulcan please? Or maybe label the knobs or something?
Plus, I was confused by the on/off bypass switch. When it's lit the effect seems to be bypassed. Was this the intention?
Thanks for sharing this too
Hi spogg...
When did this circuit, a bit confused ... so made a lot of mistakes to be corrected
... My main goal at the moment to make 3 types shaper that would copy the current-voltage characteristics of the 12aX7 standart, and Penthode...
- pentode.png (8.78 KiB) Viewed 27437 times
- Triode.png (7.63 KiB) Viewed 27437 times
Hi DigiTronix,
Labeling the UI would be a nice idea. I understand that you can overdrive the input signal and reduce gain after saturation. But I am not sure, what this saturation is supposed to do?
I could either make it distort at extreme settings, or raise loudness. But I couldn't detect a saturation on not extreme settings, just loudness. I'm not very experienced with saturation, but I would have expected a more useful curve like here:
https://youtu.be/251yMm3hOD0
I'm not sure if my comment helps you?
Hi ... I analising Softube saturation knob ,,, got here such evidence ... quite interesting, it will be necessary to work with the assembler that it would happen ... probably
- SK Test.gif (50.68 KiB) Viewed 27434 times
Are you controlling the level of 'Harmonics' ??
- StereoSpace
StereoSpace wrote:So it's a stripped-down "Green Satura"
you are talking about tor's "green eugene", i knew i saw that somewhere..
