API
API
If anyone knows...
Why does triggering this Ruby code with a button work in design mode but when I compile it to a standalone exe it doesn't work?
require 'win32API'
api = Win32API.new('user32', 'MessageBox', ['L', 'P', 'P', 'L'], 'I')
message = "This is a sample Windows message box generated using Win32API"
title = "Win32API from Ruby"
api.call(0,message,title,0)- Attachments
- apistuff.fsm
- (1.35 KiB) Downloaded 859 times
Re: API
You have to include the right ruby library folder in
$LOAD_PATH global variable
ruby use it to search the required file
When you ship or install your application in other pc, you have to enclose the required file with it.
./-- exe folder
|--ruby_library
# set the current exe ruby library directory to work with
Dir.chdir("C:\\your app folder\\ruby_library")
# list all sub directory
your_lib_dir=Dir["**/"].reject{|o| not File.directory?(o)}
your_lib_dir.each {|dir|
path = File.expand_path(dir)
# add the path to $LOAD_PATH where ruby search for the require method
$LOAD_PATH.unshift path unless $LOAD_PATH.include? path
}When you ship or install your application in other pc, you have to enclose the required file with it.
./-- exe folder
|--ruby_library
