Ruby Help
Posted: Mon Mar 14, 2016 1:17 am
by S1User
I can't figure this one out so any help is appreciated.
What I want to do is reference Ruby inputs via var assignments to me the code shorter. For example, say I have inputs named....
value
bg1
font1
border2
bg2
font2
border1
And I want to reference them all in the same block without repetitive coding like below where I'd need separate code blocks for items 1,2,3,4,5,etc...
If value == "1 then
output "myoutput", @bg1
I need some way above to replace" @bg1" with an object var that can be assigned in real time to reference that input directly, a way to build a var or string that is recognized as an input object by combing the "1" from the value with something else to make an object reference on the fly that's recognized as being @bg1. Is that possible?
In VB you can do that with strings like Controls.Find("bg" & value), and it would locate the object and allow assigning an object var to it to reference it on the fly. Does Ruby have anything similar?
Thanks.
Re: Ruby Help
Posted: Mon Mar 14, 2016 1:15 pm
by Tronic
def event i,v,t
# usage:
# @var = get_input_by_case("input_label")
# @var = get_input_by_case("input_label", value)
watch @b = get_input_by_case("bg",@value)
output @b
def get_input_by_case(label,value=nil)
get_ = value ? "@" + label + value.to_s : "@" + label
instance_variable_get(get_)
Re: Ruby Help
Posted: Mon Mar 14, 2016 3:42 pm
by Tronic
Re: Ruby Help
Posted: Tue Mar 15, 2016 6:16 pm
by S1User
Thanks a lot Tronic. Much appreciated.
On another note, I'm a VB guy and Ruby is new to me so I'm learning. How does this code below look to you? It works but I wonder if it could be done better or smaller. Thanks.
Edit: Holy crap, that previous code I posted was a mess.
def event i,v
if i.name == "trigger" then
if File.exists?(@folder) # if the client folder is a valid folder
$SesCount = 0
$Hours = 0
$Total = 0
# look at all files in the current client's folder
Dir.foreach(@folder) do |item|
if item == '.' or item == '..' or item ==''
# skip these nonsense listings
else
# update the session file count
$SesCount = $SesCount + 1
# Read each file into an array to get the data
sesAry = []
IO.foreach(@folder + item) do |line|
sesAry.push(line.chomp())
# update the running totals
$Hours = $Hours.to_f + sesAry[3].to_f
$Total = $Total.to_f + sesAry[7].to_f
# display the totals to the user
output "sessions", $SesCount.to_s
output "hours", $Hours.to_s
output "total", $Total.to_s
Re: Ruby Help
Posted: Wed Mar 16, 2016 2:40 am
by Tronic
Some things to keep in mind is the difference in how you assign the variables.
Class variable (@@a_variable): Available from the class definition and any sub-classes. Not available from anywhere outside.
Instance variable (@a_variable): Available only within a specific object, across all methods in a class instance. Not available directly from class definitions.
Global variable ($a_variable): Available everywhere within your Ruby script.
Local variable (a_variable): It depends on the scope. You’ll be working with these most and thus encounter the most problems, because their scope depends on various things.
continue here...
http://www.sitepoint.com/understanding-scope-in-ruby/below my version
def event i,v
if i == "trigger"
sesCount = 0
hours = 0
total = 0
# advance if not is an directory
next if File.directory? item
sesCount += 1
hours += File.new(@folder+item).readlines[3].to_f
total += File.new(@folder+item).readlines[7].to_f
output "sessions", sesCount.to_s
output "hours", hours.to_s
output "total", total.to_s
# comment this if not need to debug
watch "debug", [sesCount.to_s,hours.to_s,total.to_s]
