FS2: Still Bugged?
Posted: Wed Jan 04, 2012 9:02 pm
by Tronic
No update planned for Flowstone 2?
No gems support?
Add other function from current releases of ruby, not possible?
"Excessive processing detected. This component Ruby has benn turned off as precaution"
This message is from the Ruby primitive.
Ruby limiter?
This does not allow to use some simple functions of the Ruby language, will be resolved in the future?
Re: FS2: Still Bugged?
Posted: Sat Jan 07, 2012 10:09 pm
by Tronic
no answer?
Posted: Sun Jan 08, 2012 6:27 pm
by DSP
No answer necessary.
It's only been out a week or so, and it does 99 % straight out of the box.
If you would like FlowStone to be successful and develop, then maybe you should conceder naming your posts 'Fantastic product, here's my wish list'
If you read the other posts about Ruby Gems you will see it is possible but the issue is that most of the gems don't work on windows! This is not a FlowStone issue!
Posted: Mon Jan 09, 2012 6:06 am
by Tronic
I do not want any controversy, but honestly disagree with you.
Posted: Mon Jan 09, 2012 11:48 am
by sal
at the moment gems are not working in ruby module and even gems that works flawlessy using ruby on windows are not supported, so it's definitely a flowstone issue.
Mr dsp, this is the second time you write that ruby gems are supported, but if you think so, please explain how, because this is not possible at the moment as confirmed by flowstone developers.
Posted: Mon Jan 09, 2012 7:07 pm
by Tronic
I also forgot to say that does not work, it also
Bug
