A new approach to trigger limiting
Posted: Sun Dec 27, 2015 5:51 pm
While working on r2 of the True Vector Pad (yes, an update is coming soon!), I needed a trigger limiter for the preset parameters that are sent from the preset manager to the module. The limiter prim is bound to the redraw rate, so I thought a Ruby solution could work even when there are no redraw triggers.
I kind of was successful. Indeed my solution limits incoming triggers, but it is very inaccurate the higher the limit rate is set. For example, at 10 triggers per second the real output rate is around 9.6 tps which is ok. But at 30 tps the real output rate is around 23 tps, etc.
I've made a test schematic for all you Rubyists that you can play with and hopefully optimize!
