A new approach to trigger limiting
While working on r2 of the True Vector Pad (yes, an update is coming soon!), I needed a trigger limiter for the preset parameters that are sent from the preset manager to the module. The limiter prim is bound to the redraw rate, so I thought a Ruby solution could work even when there are no redraw triggers.
I kind of was successful. Indeed my solution limits incoming triggers, but it is very inaccurate the higher the limit rate is set. For example, at 10 triggers per second the real output rate is around 9.6 tps which is ok. But at 30 tps the real output rate is around 23 tps, etc.
I've made a test schematic for all you Rubyists that you can play with and hopefully optimize!
- Trigger Limiter.fsm
- (2.78 KiB) Downloaded 1219 times
Re: A new approach to trigger limiting
Here is an alternative. It has a queue with configurable length in case you don't want to lose triggers which come too fast. Set qSize = 0 if you don't care. qSize >= 1 will output the desired rate, qSize = 0 will result in less than that because no buffering takes place.
- Trigger Limiter(MV).fsm
- (3.13 KiB) Downloaded 1213 times
Nice! A queue of course! Went into my toolbox. Thanks!
I like to use this code for trigger limit, and also I can execute an block of code with it.
sorry only text editor avaible....
I think it work....
Edit: make the example more clear, for block.
I think it work....
def init
@block_test = 0
def event i, v , t
trigLimit(100) {
watch "block_executed", @block_test+=1
output 0, nil
def trigLimit(d,&block)
@i ||=0
if @i<d
@i+=1
else
yield if block_given?
@i=0
endEdit: make the example more clear, for block.
