Youlean FIR Filter DLL
Youlean
Post by Youlean »
Just DLL implementation of FIR filter.
Edit: Reuploaded...
Youlean FIR Filter DLL.zip
(196.79 KiB) Downloaded 1475 times
Re: Youlean FIR Filter DLL
Youlean, is that an FFT convolution in your external DLL? In the schematic you mention "unlimited size". How much would that be, enough for an offline reverb? :?:
Youlean
Post by Youlean »
martinvicanek wrote:Youlean, is that an FFT convolution in your external DLL? In the schematic you mention "unlimited size". How much would that be, enough for an offline reverb? :?:
I recreated everything that is inside original MyCo module. Yes, it should work with any coefficients size as long your CPU and RAM allow it.
Youlean
Post by Youlean »
Sometimes it will crash when you change coefficients size from big to small, but I think that this could be because of frame and green DLL update.
I think that stopping frame update before coefficient update would fix that...
