Clock Accuracy - 10ms?
Posted: Fri Nov 20, 2015 11:38 am
The manual says:
The schematic clock runs at 100 Hz. Unlike the Tick components which are not time precise due to
their use of Windows timers, the Events system uses a different timer which is much more accurate so
each 10 millisecond tick should occur precisely on time.
This means that if I call events under 10ms they might be not in synch? For example:
call an event every 1 ms. So 10 times between 2 clocks. They can be un-synch so? Occuring essentially not every 1 ms?
This could be a problem, since I'm making a LFO that change many values during the time, that will occurs around 1ms or less...
input 10, nil, time + 0.001
