Multi stage envelopes fixed with re-trigger working
Hi all
As per another Topic here are two similar graphic multi-envelope modules. In the originals you could select re-trigger on or off (right click pop-up menu) but the result was always off. They ran up to the end of the Sustain phase but would not re-trigger. This is bad when a limited number of voices are set and especially for Monophonic (singe voice) settings.
I hope they find a place in your toolbox!
Multi stage graphic envelope generators with working re-trigger.fsm
(253.15 KiB) Downloaded 1654 times
