Ruby: Error messages that don't help
In this short example it is pretty obvious. The original int was converted to a float and now can't be represented as a hex string. But the error message is just annoying. Imagine you get this message, as happened to me, in a draw method filled with a few dozen of lines. Further imagine that you used a method to convert to strings of various forms, so that you don't have something like "drawString mynumber.to_s(16)", but "drawString mymethod". Still the error is reported for the draw method...
Took me half an hour to find the cause.
Re: Ruby: Error messages that don't help
trogs error tracing code snippet helps a lot to find the issues
viewtopic.php?f=3&t=1291
and you can edit the ruby editclass to get the code with linenr
here is the topic: viewtopic.php?f=2&t=2712&start=10
after this was requested already a few times it really would be great to get line-numbers implemented in the ruby module in one of the next updates..
Nubeat7 wrote:trogs error tracing code snippet helps a lot to find the issues
Thank you very much!
I always tend to believe that I'm the only one who is annoyed by something like that.
