Advanced Envelope
Father
Advanced Envelope
Post by Father »
This is a tool that can be used to control other parameters to change in time. You can use it to control volume, filters...etc. Hope it could be useful and maybe someone could find and fix the bugs or come up with something better.
Special thanks goes to TheOm for his beautiful work on Line Editor, and Nubeat7 for his help with position sync.
Known issue: It doesn't always load right, specially in bigger projects, apparently due to ruby's loading problems.
enjoy.
Advanced Envelope.fsm
(496.6 KiB) Downloaded 1514 times
Re: Advanced Envelope
I was just thinking about creating an envelope from TheOm's editor for a project myself. Will have a look for sure; thanks!
StereoSpace
Post by StereoSpace »
Wow)) Thanks!!!
GUI designer
StereoSpace
Thanks!!!
GUI designer
lalalandsynth
Post by lalalandsynth »
Wanted to try this , has an error inside module , seems to be the code.
Is there a more recent version or something similar , looking for something like the Envelope in Massive.
lalalandsynth
Wondering if this works for other people , seems to be an error in the preset setting .
Does not work at all for me at the moment , might be doing something wrong ?
lalalandsynth
Sweet, got it working , anyone have an idea how i can resize this thing ?
Any attempt will crop the grid which makes it work wrong.
Wassaka
Post by Wassaka »
lalalandsynth wrote:Sweet, got it working , anyone have an idea how i can resize this thing ?
Hi! To resize it, just resize like a normal module and then press double click on "line editor" to resize it. (Sorry for my bad english :? )
Advanced Envelope (Resized).fsm
Here is an example.
(163.84 KiB) Downloaded 1315 times
lalalandsynth
Yes, but now you have 12 grids instead of the needed 16 .
It does not work properly like that.
lalalandsynth
I have built a plugin around this advanced envelope but during testing I noticed that it creeps up in memory usage .
Faster if the GUI is open.
Can anyone check and confirm ? Tested 3 computers. 3.08 export as well as 3.09.
