Maximum value from mem buffer?
Youlean
Post by Youlean »
Is there any way to get maximum value from a mem buffer with stream connection (not green)?
I need to find max value from 1024 buffer, and so far I made it with stacking one sample delays, but CPU usage is insane...
Re: Maximum value from mem buffer?
Connect the buffer to wave read prim with index counter and connect that to this:
streamin in;
streamout out;
out=max(out,in);
connect that to analyzer prim, and read the last value from the output float array (the number of values to process should be equal to the size of the buffer).
Alternatively you can use memin input and put the index counter into the code block dirrectly.
Youlean
Post by Youlean »
Well, I don't think that this will work...
I need to get new max value every sample from 32 samples buffer.
Is this possible with ASM, or ruby?
BTW, thanks KG for helping me out...
it is possible with code component using loop if the buffer is array
c=0;
maximum=0;
loop(32){
maximum=max(maximum,array[c]);
c=c+1;
Youlean
Post by Youlean »
KG_is_back wrote:it is possible with code component using loop if the buffer is array
c=0;
maximum=0;
loop(32){
c=c+1;
Sorry KG, but can you write the whole code, I don't understand how to implement this... :(
Oh sorry, I think I'm missing the point. So there is something happening with the buffer (you are writing to it at some place in the schematic using write mem prim or asm) in every sample and each time you then want to find the maximum value in that buffer each time, every sample. Is that right?
Youlean
Post by Youlean »
KG_is_back wrote:Oh sorry, I think I'm missing the point. So there is something happening with the buffer (you are writing to it at some place in the schematic using write mem prim or asm) in every sample and each time you then want to find the maximum value in that buffer each time, every sample. Is that right?
Yes.
Ok! that needs ASM to work. This should do it...
memMax.fsm
(1.09 KiB) Downloaded 1371 times
Youlean
Post by Youlean »
Sorry for late response..
Thanks a lot, but this is not what I am looking for...
I am looking for something that will emulate "finding max from 16 samples" in my example with much less CPU usage.
Hold max custom amount of samples will not work here, as it is slightly different from finding max from 16 samples...
BTW, is there a way to have really optimized fixed delay (that will delay signal for fixed amount of time). To be low on CPU as one sample delay?
Thanks!
Max From Array.fsm
(20.33 KiB) Downloaded 1344 times
Oh, now I get it... this can be done in code component:
streamin in;
streamout out;
float buf[16];
float c,d;
buf[d]=in;
d=d+1;
d=d&(d<16);
c=0;
out=0;
loop(16){
out=max(out,buf[c]);
c=c+1;
It can be optimized in assembly, but the functionality is there...
As for the delay:
streamin in;
streamout out;
int c=0;
float mem[1024]; //this can be of any size
mov eax,c[0];
add eax,-16;
and eax,16 383; //looping mask - this will force "c" to cycle in 0-16383 range. Works only with powers of two minus one
mov c[0],eax;
movaps xmm0,in;
movaps mem[eax],xmm0;
add eax,{delay*16};
and eax,16 383;
movaps xmm0,mem[eax];
movaps out,xmm0;
This should be the most efficient way to do the fixed delay. Just copy-pase this code into assembler and insert your desired delay multiplied by 16 on the spot "{delay*16}" I have made the buffer fairly big, you may opt to use smaller buffers (it will not make much difference though) if you want - in that case replace every "and eax,16 383;" with 16*buffersize.
You may even easily modify it, to output multiple delays of the input. Simply copy-paste last four lines multiple times - keep in mind the delays will be differential (every next computed delay is computed from the position of the previous one)
