RUBY Encoding format
Drnkhobo
Post by Drnkhobo »
Hey guys, im trying to parse some txt files for emails & I get an error within Ruby:
Encoding: (in method 'event')::ConverterNotFoundError: code converter not found (ASCII-8BIT to UTF-8)
Now, I can parse emails one by one which its fine, but as soon as I try to do a whole directory it gives this error. I am going through each one and adding them to an array. . . take a look:
@db = []
Dir.foreach('C:\S') do |item|
next if item == '.' or item == '..'
newfile = 'C:/S/' << item
f =  File.open(newfile)
content = f.read
r = Regexp.new(/\b[a-zA-Z0-9._%+-]+@[a-zA-Z0-9.-]+\.[a-zA-Z]{2,4}\b/)
emails = content.scan(r).uniq
addy = emails[-1]
@db << addy
output @db
So as I said, it works fine until I try to parse a lot of files. It gets through about 15 or so before stating the error. I have just exported my emails from thunderbird so they are .eml files.
Its weird because it goes through like 15 before spitting out the error. :?
I have checked online and tried a few solutions to no avail. Does anyone here have experience with the Encoder functions? Why give an error after doing a few then stopping?
Re: RUBY Encoding format
You said you tried something from the web without specifying what exactly. So excuse me, if this is not helpful.
This will inform ruby of interpreting as utf-8 without touching the byte sequence of the file
content = f.read.force_encoding("utf-8")
Another chance might be that the byte sequence is read in wrong. This will do a conversion, but then again tell ruby to handle it as utf-8
content = f.read.encode("iso-8859-1").force_encoding("utf-8")
Lastly a double conversion might help
content = f.read.encode("iso-8859-1").encode("utf-8")
ASCII-8bit shows that somehow the data is interpreted as binary instead of string. But I don't know why.
Drnkhobo
Post by Drnkhobo »
Thanks Tulamide :D
I will give it a go now now, I did try to force encoding but your solution looks like it might just work for me (how do I know :roll: :lol: )
Its weird that if I put 10 emails in my folder it does its job fine without complaining. As soon as its more than that, the error spits up. Strange. . .
Ok, I thought about the weird behavior. Don't laugh: Are you sure, the folder contains nothing else than human readable text files? Maybe there's some hidden system file among them or another binary?
I ask because your code does not protect against reading those in.
To be absolutely sure, you could extend the if statement with
next if item == '.' or item == '..' or item[-3, 3].casecmp("eml") != 0
tulamide wrote:ASCII-8bit shows that somehow the data is interpreted as binary instead of string. But I don't know why.
This might give you a clue...
Encoding.name_list
#=> ["ASCII-8BIT", "UTF-8", "US-ASCII"]
If I do the same thing on my standard Windows Ruby 1.9.3 install, I get 99 different available encodings!
So, the FS version of Ruby has had huge amounts of the Encoding class ripped out. I can only guess that this is partly to enforce compatibility with the "green" strings, which are always ASCII, and maybe just to reduce the Ruby interpreter size for embedding into exports. It is very annoying - I had hoped that Ruby could be used to allow proper Unicode support, but it seems not!
trogluddite wrote:This might give you a clue...
It does :mrgreen:
Tbh, I didn't even think of checking it. I just assumed a fully functional ruby. :cry:
@Drnkhobo
Ignore the last two "content" examples. They won't work under these circumstances. And let me know, if one of the other tips helped you.
I spoke to Malc about the problem with international characters (editboxes in edit state and difference between string prim vs text prim) because I can't display some things proper in my language, and he said he will check it. Since FS is expanding into less audiomatic areas - I think this issue may land on the priority list.
Would be a valuable thing for users of any language - it would open the doors for working with many kinds of external documents, and most of the Windows API assumes multi-byte character encodings as standard. For example, I have had to use some really ugly hacks to make the DLLs I'm working on call Windows functions successfully when they have string arguments.
JB_AU
Post by JB_AU »
Don't forget attachments, eml can contain binary attachments.
Albert Einstein
JB_AU
Post by JB_AU »
I'm not 100% sure what sequence of events you need.
So its possible to set Preference file to view as html or plain text, 1 less conversion step.
Retrieve mail, parse tags, dump it, do stuff.
The long range drone (50km away) i parse sms as (plain text)
Parse the sender tags, for a specific sender id.
Then set predefined condition by subject tag.
I'm not using Ruby that i know of!
Hope this helps?
Albert Einstein
