Synthmaker Member's Forums
Posted: Sun Jan 12, 2014 9:04 pm
by Perfect Human Interface
So as far as I can tell, there are a lot of goodies on the Synthmaker forums hidden in the "members forums," which require a login to access. Also as far as I can tell, there's no way to sign up for the forums there. Presumably if you already have an account you can sign in but they've disabled sign up after the move to the new forums here.
What's a guy to do if he wants access to those goodies?
Re: Synthmaker Member's Forums
Posted: Sun Jan 12, 2014 11:24 pm
by tester
If you are FS or SM owner (legal purchase, full version) - it should be no problem to get you there. Just let me know on PM.
Posted: Tue Jan 14, 2014 1:55 am
I only have the FL Studio version of Flowstone, so I assume then that this isn't enough to gain access to these "members forums."
Posted: Tue Jan 14, 2014 1:03 pm
by tester
Trog - what was the status of such situations on SM forum?
Posted: Tue Jan 14, 2014 8:14 pm
by trogluddite
tester wrote:Trog - what was the status of such situations on SM forum?
Not a problem I ever encountered - but judging by the ease with which spammers spread their demon seed there, I don't see that there is any technical reason that admission is barred.
Posted: Tue Jan 14, 2014 11:56 pm
by tester
If my english is correct (even GT had a problem to digetst the last part to my lang), I pass PHI's request further tomorrow or so.
Posted: Wed Jan 15, 2014 1:50 pm
by tester
PHI - I forwared your request to get SM "Registered Area" access to Malc (since he is the owner of SM board - he decides). If everything is fine, within few days you should be able to use that part of the forum.
Posted: Wed Jan 15, 2014 7:59 pm
Sincerely thank you for going out of your way to do that.
Posted: Thu Jan 16, 2014 1:45 pm
by tester
PHI - you may login now on SM using your current user details, and you should have access to Registered Area too. Let me know if there are any problems. Have fun! ;-)
Posted: Thu Jan 16, 2014 2:45 pm
Thanks so much.
