LA Kit - 808 - Sub Boom Drum Machine coming soon!
- wlangfor@uoguelph.ca
So, I've paired up with BDP (bigdreamproducer.com) and We have been getting ready to release a drum machine. The source code though will of course be open source. It will have something that's a bit different. A shelf EQ for each sample / pad, as well as pitch and stereo width.
I will also find a way of getting a more efficient adsr built in. I might be able to post a beta of it tonight.
There was someone I am making something for as well, it's something that will pickup keyboard keys pressed to make it easier for people to work with synths in fl studio. And furthermore there is two modes in fl studio, so I'll have to consider adding global settings with an .ini file.
With that, it would be possible to mimic the ableton style as well. It's just a matter of matching the keys and notes equivalent. However, ableton allows changing the octaves in a global way (ctrl,+) while fl studio employs this on a piano roll to piano roll basis.
So, assuming that I can get the x64 beta, BTW, on slack; could'nt find the beta. Could someone pm Me the DL url? I'm registered with the beta prog but I did'nt have the time to find that. I'd post feedback of course.
- lalalandsynth
Re: LA Kit - 808 - Sub Boom Drum Machine coming soon!
you have to ask for access to the Alpha section in the Alpha forum, there you will find the 64 bit version.
lalalandsynth wrote:you have to ask for access to the Alpha section in the Alpha forum, there you will find the 64 bit version.
OK, on slack or here?
