extension manager
extension manager
I'm not quite happy with how the open/save dialog works, so I made this one.
- It should always add the extension, no matter what viewing settings you have under Windows (show/hide extensions).
- It will add prefix or sufix to your filename (you can use date generator for example or some sort of sufix marker).
- It will have no viewing issues in file dialog window.
- It's easy to configure (I hope I configured it correctly inside).
- It will make easy to manipulate the extension within your project.
- It will output for you also parameters of your operation (path, filename, etc.)
//edit:
v.1. adds " " to paths (useful when paths are containing empty spaces).
//edit2: these ones are optimized for saving.
//edit:
- extension-manager1.fsm
- (2.58 KiB) Downloaded 978 times
- extension-manager.fsm
- (2.45 KiB) Downloaded 953 times
Re: extension manager
Now it should work both ways (prefix/sufix removed when opening). Plus - triggers reduced to correct rate.
//edit: ...and smal update.
Note: If you are using dynamic prefix/sufix, you may need reorder some triggers (prefix/sufix sends s&h trigger for incoming path, so that the path is sent further after prefix/sufix are added).
- extension-manager3.fsm
- (2.9 KiB) Downloaded 903 times
- extension-manager2.fsm
- (2.89 KiB) Downloaded 935 times
...actually, for dynamic pre/sufix - this should handle it.
- extension-manager3a.fsm
- (3.04 KiB) Downloaded 1000 times
How do you make your own file extension? I need to now how to make my own file type and my own extension, to create a application that can read it to do SOMETHING programmable.
_____________________________
street fashion blog ~ best fashion blogs
Prove that you are not a bot.
Rephrase your question.
