New Gain Rider named LA Ride (Beta)
Posted: Sun May 26, 2019 6:19 am
by wlangfor@uoguelph.ca
HI all, I made this tonight because I needed a gain rider. I need to change the colour just slightly but I'm happy so far.
Here it is:
[new version on last post]
I haven't got presets working yet, but will.
Re: New Gain Rider named LA Ride (Beta)
Posted: Sun May 26, 2019 10:20 am
by lalalandsynth
What do the sliders do ?
Posted: Sun May 26, 2019 2:50 pm
lalalandsynth wrote:What do the sliders do ?
They choose Your threshold of +db and -.
So, if You want silent sounds to be louder, the bottom one higher, and if loud but less so, the high one closer to the lower.
It's a way of controlling peaks that is not limiting. It's exponential governance by means of amplitude percentile.
I'm also going to add a great code by Sam Mungall which is a db matching prog. It does something the same but You can set the overall desired volume. I thought I would make that an option.
Here's the updated beta. Most presets work, but not the sliders (yet).
[see below post for link]
Posted: Sun May 26, 2019 6:03 pm
Check out the newest that seems to work in the way of presets. I'm not sure about automation though.
Also, I need to restyle and order the presets by label and #, add labels, vst info and such. But a working example.
Find that here:
http://dsprobotics.com/support/viewtopic.php?f=3&t=18239
