Porting to Mac with Winebottler - List i need to know
chackl
Post by chackl »
Well this is on of those Topics that might be hated by mac-haters.
Well i'm a 'little' hater too but there are users there outside that are let me say 'only able to work on mac'
So this Pic will get you up - and NO - this is no fake!!!
This is FlowStone Free runing on an OSX 10.8.5 powered with Winebottler:
(App gets arround 700mb :P)
Well - I have to say - it run for eaven 10 seconds before it crashed ^^
BUT:
I think i just got some settings wrong that are forced in WineTrick - WineTrick lets you Import libs from Windows example MS-Framework - some dialogs - AND GDX+ (called gdxplus)
I found out that FlowStone will Need GDX+ and the standart Windows Fonts otherwise the Programm Looks like a cutted peace of paper.
So my Goal is NOT to get the whole FlowStone to Mac - and NOT VST to AU!!!I want to get exported EXEs to mac-users.
And for that i Need to know some Basics:
What modules of Windows are used by FlowStone or FlowStone exported EXEs?
Example those i could get loaded:
GDX+ for Graphics
DirectSound for Sound
Force Sound to CoreAudio
But ther must be some more - because ruby is crashing all the time and i mostly could get it working for only 2 minutes
Shure! I'll post results if all is finished - Because this might be interesting for mac users ;)
Regards
C.Hackl
chackl
Re: Porting to Mac with Winebottler - List i need to know
Post by chackl »
Well got some news:
Winetricks Settings: (check all those elements listed here)
cmd
dinput
directmusic
directplay
dmsynth
dxdiagn
dsound
gdiplus
hid
mfc40
msscript
vcrun6
mfc42
msvcirt
vcrun6sp6
vcrun2003
vcrun2005
vcrun2008
vcrun2010
windowscodeccomponent
xinput
consolas
corefonts
lucidia
tahoma
ddr=gdi
sound=coreaudio
win7
Here is the link to the Winebottler Project:
http://winebottler.kronenberg.org/
Issiues:
Startup error - but "normal" environment for FlowStone
Bitmaps are everytime NIL or NULL - they are not loaded correct - some dll is missig here tht i could not find
Audio is verry laggy with clicking noises
Wine is not starting a virtualWindows - it is emulating an Environment - so the FlowStone.app will get about 660 Mbyte when the built is finished.... I know i may have loaded to much now - i just wanted to check it.
Any more Ideas here?
May a mail to the dev make more sence here?
Regards
I sent you PM, something I'd like to test on MAC. If these apps works, then I prepare some mix with reaper, would be great to get them running.
You should get my PM within few hours I guess (I'm not sure if FS is sending messages on the fly or once per day or else).
chackl
Post by chackl »
Well it does not make any sence until FlowStone it self does not run :P
I told i'll do no port - This means i'm not trying to get it stable after everything is working. But if FlowStone it self will be able to execute all things that (like now load and draw Bitmaps) - the exported exe files will be no Problem.
So i did not try but i may gues whats hapens on mac with the current things:
If you have the Pic as Ruby load it may shut down al ruby components inside
The load time is verry Long now on Windows - Load times will dublicate on mac
And i'll write you a pn back ;)
Regards
yes thats one of few promising port win to mac projects, there is also a commercial company using it, codeweavers.com port your app to mac format, for a few thousand $ and a licence fee for every sold app,
they do everything for you including a macinstaller..
they also ported FL to mac! hmm, maybe they will port FS one day anyway when FL is already done how far could the step be? FL would find it good too that FS-FL would be avaliable for the mac version too!?
anyone has experience with FL on mac ?
chackl wrote:But if FlowStone it self will be able to execute all things that (like now load and draw Bitmaps) - the exported exe files will be no Problem.
you really think that exe export would be possible? do you mean executables for mac? arent they called different
what about ruby will it work?
chackl
Post by chackl »
Well i think this may take a while :D - I've done plugins vor VirtualDJ on Mac and..... dont talk about it ^^
So if you Need a quick solution - here we go :D
Well i tested it now and it seems to work for some simple operations.
The joke:
If you load a file with the filedialog (coming from Winebottler - so the Dialog is like on mac) - You'll see parts your mac System. so some path Parameters E.G Documents or Desctop bekome mac equivalent and will take the Folders of mac. The mac System Folder is not accessable.
Belonging Ruby - when i integrated the VC2008 packs ruby was runing normal.
Only Problem at the Moment: No Bitmaps - None!!! - Not loadable.
Ther is some lib that FlowStone is using from Windows that i did not find and i hope some head here knows something about that.
EDIT Just noticed that the common dialogs are not updating the string. I make some tests tomorow.
chackl
Post by chackl »
I have now an updated list for the Winetricks:
comctl32
crypt32
dsound => if your app needs Sound
gdiplus
vcrun2005
vcrun2008
vlc  => if your app needs Videodecoding and Streaming
Issiuses i have found:
Speed:
Everything is a little slow. but faster than with a virtual machine.
Bitmaps:
If you load a bitmap from a filepath - you'll get no bitmap to the connector
If you load a bitmap on Windows and save the fsm and load it to mac - the bitmap will be displayed correct
Filesystem:
This is a little spetial - you have 2 drives - C for Windows and Z for mac
C:\Users\User\ will be replaced by the User folder of mac.
The complete C:\ system is inside the APP - as long as you do not clear the cache flowstone will save everything you did on C:\
If you export the comlied exe on windows and run it on mac with winebottle - inside saved bitmaps will be loaded.
If you drag something from the Toolbar with a bitmap it would not work.
Ruby:
I had no errors during testing - you may not be able to do WinAPI calls
Sound:
Clicking and other noises - there might be another optimation to emulate ASIO
Tronic
Post by Tronic »
try to add this:
mfc71.dll
msvcrt71.dll
and you have to make the right GDI plus setting?
