random selections
random selections
Speaking of the future. Array based slider concept brought by Nubeat7 introduced few questions for me. So here is one of them. Ruby based (I guess) random generator vs array.
Let say, that the first array, is the float array, and its size is fixed.
23.000
33.000
21.000
65.000
Let say, that there is second array, that refers to indexes of the first one, array containing int 0's and 1's.
0
1
0
1
Zero means, that at that index, in first array (float array) - value is untouched. 1 means - that at that index - value is being randomized. These 0's and 1's come from on/off buttons.
How to pick selective randomization that way, via ruby?
There could be third and fourth array :-) for min/max, but let say that min and max values are common for all.
Second part to that question would be, to pass these randomizations through "logarithmic spread" (the same amounts of hits per octave), to get more lower values, but my head is too small now to visualize that.
Re: random selections
If I follow ...
Using RUBY to make choice distinctions ... would maybe involve the IF condition, or the CASE statement.
Here is one example I refer back to and help me recall this in Ruby.
score = @in
# score = 70
result = case score
   when 0..40 then "Fail"
   when 41..60 then "Pass"
   when 61..70 then "Pass with Merit"
   when 71..100 then "Pass with Distinction"
   else "Invalid Score"
output result
the INTEGER INPUT I labeled 'score'. The string ouput I have sent to Output 0.
This is just a generic ... but can help illustrate ... and hope this is of help !
Watching at the code contents, I'm not sure if it's the answer to the question.
Maybe I explain a little bit. Right now - I'm using set of single units (clones). They can be randomized all at once (whole array so to speak), or just selected clones only (equivalent would be: selected values on array, at indexes chosen via second array).
Some of these randomizations are refering to frequencies, and at these parts - a nonlinear function is used, to make the spread of hits "equal across the octaves". And - yes, it is (and should be) based on frequencies, not pitches.
Right now these are just free thoughts, I'm starting to see the greater picture..
that 's what the example pointed to ... even a 'random selection' will have to select. The simple code is only to illustrate a possiblity.
TrojakEW
Post by TrojakEW »
this is array you want to alter:
a = [23,33,21,65]
this is range you want to choose for randomization (example)
b = [11,22,33,44]
now lets say user or you want to randomize first index (0) out of four
a[0] = b.shuffle.first
result array with only first index randomized in selected range:
a
Don't know if is this what you want.
I think i meant something like this...
...with included editing option (forgot to add there).
selective-rand-array.fsm
(640 Bytes) Downloaded 1018 times
you mean something like this?
0.upto @frequencies.length do |i|
   if @randomSelections[i]==1
     @frequencies[i] = rand(60..44100)
output @frequencies
edit: ahh, saw your example.. so this should do the job
Where is the trigger? :-)
How to trigger selective randomization?
selective-rand-array1.fsm
(544 Bytes) Downloaded 918 times
use array ins and out, if you want a trigger, write it inside the event methode and add a trigger input..
if'triggerIn'
..methode
TrojakEW
Post by TrojakEW »
Since I don't know what do you want for output and what for input I made two versions.
selective-rand-array1-2.fsm
or like this?
(488 Bytes) Downloaded 974 times
selective-rand-array1-1.fsm
likethis?
(467 Bytes) Downloaded 899 times
