MouseCursor Position
billv
Post by billv »
The default FS knob behaviour is not good for fast tweaking..... :evil:
Start at 0 ...go all the way to 1...and your mouse cursor ends up
4 inches up the screen.... :roll:
So I just need to put the original cursor position back in when the mouse goes up...
But having trouble trying to write it in...
Should it look something like this...
def mouseCursor x,y
if i == 1 or 2 then
mouseCursor.pos = @inputx,@inputy
billv
Re: MouseCursor Position
Post by billv »
How do you control cursor position without using the cursor...?
Is possible..?...
why not using the show cursor primitive? you can set "hold position while dragging"
billv
Post by billv »
Nubeat7 wrote: "hold position
Thanks Nubeat7....didn't notice that...
strangeChild
Post by strangeChild »
billv wrote:So I just need to put the original cursor position back in when the mouse goes up...
That was the default behaviour with SynthMaker stock knob... I say it should be for FS too.
SynthMakerKnob.fsm
(131.65 KiB) Downloaded 959 times
strangeChild
Is there a Ruby method available to set the cursor position? :?
strangeChild
Nubeat7 wrote:why not using the show cursor primitive? you can set "hold position while dragging"
Ah! I didn't get this right away...
Still... is there a Ruby method for setting the cursor position?
