Ruby nuby needs help
strangeChild
Post by strangeChild »
I wrote a Ruby module to replace some green math just to learn a bit... after discovering 1/12 = 0 but 1.0/12 = 0.083333333 things went more or less as expected.
But when I reopened the schematic it was flagging a Ruby error... I couldn't figure it out as it looked OK and had been working when I saved... then I discovered if it clicked on each of the inputs it would resolve the error...
Here's the code the module contains:
def _Nx12thRoot2Inv(x)
   1.0/2**(x*(1.0/12))
scaleLength = (@fbWidth - @nutThickness - 0.5*@fretWidth )
scaleLength = scaleLength * (1/(1 - _Nx12thRoot2Inv(@Nfrets)))
output scaleLength * (1 - _Nx12thRoot2Inv(@fretNumber)) + @xOffset + @nutThickness
(It's for the fret x offsets on a guitar scale display.)
Can anyone sort me out on this?
strangeChild
Re: Ruby nuby needs help
The file is stable now... and I didn't keep the version where this happened and can no longer replicate.
I believe it had something to do with the fact that I had saved some invalid code and then deleted it and saved again... after priming each input with a trigger the code saved properly. :?
chackl
Post by chackl »
Hey - This is not strange - you may take a look to the definitions of Float and Integer ;)
12 is interpreted as Integer
12.0 is interpreted as Float
For example:
1/12 means
Integer / Integer = Integer - An integer is an Integer so no dos will be stored
If you write:
1.0/12.0 means:
Float = Float/Float and you will get your expected Value
So ruby takes always the highes Level object in a line and converts it - This means:
1/12.0
Integers / Float = Float
1.0/12
Float / Integer = Float
If you want to convert values of a Variable:
@var1=1
@var2=12
@var1 / @var2
=> 0
@var1.to_f / @var2
=> 0.08333333333333333
Regards C.Hackl
strangeChild
Yeah... once I figured out what part of my code didn't work I knew it was a typecast issue.
That's the downside of not having to declare variable types.
Has anyone else experienced problems saving files after a Ruby module with an error was deleted... that was my real problem here.
