New LA Bands 2 EQ
wlangfor@uoguelph.ca
New LA Bands 2 EQ
LA Bands 2 is a great equalizer that's recently been updated. It runs at about 0.5% of the CPU and has a huge amount of tweaks to make everything work just right. :)
la bands 2 v0042 global redraw public.fsm
1.4
(298.3 KiB) Downloaded 1159 times
Last edited by wlangfor@uoguelph.ca on Thu May 30, 2019 5:49 pm, edited 9 times in total.
My youtube channel: DSPplug
Halon
Re: New LA Bands 2 EQ
Post by Halon »
Looks really nice.
Halon wrote:Looks really nice.
Thanks Mate :), I was tinkering around with the ratio of resonance and started on a female and male vocal version as well. The female version is done but the male version demands a different balance with the bass and resonance.
I'll update when I can. Also, thanks to Spogg I've found a new technology with which to make a parametric EQ which should be even more efficient than the style which I used for the ZDF EQ.
More on that soon too.
Halon
Post by Halon »
Cool. Was this done in Ruby?
Halon wrote:Cool. Was this done in Ruby?
Well, some was. But I'd had an issue with the dropdown menu conflicting with a ruby regular expression parser.
I'll probably solve the problem by making the expression parser also the dropdown builder so that there is no differentiation between the menu and the c++ code running in the background.
I'd update a preset and due to the fact that categories were not displayed in the menu as well as ",<<," You have to add one as well the current category number to add to the dropdown display and then subtract the same number before the chosen number gets re-routed to the plugin preset prim.
But they run at different speeds.. of course, lol.
Speaking of which though I need to get a bipolar rational mapper to improve the sound of this eq. then I can thin out resonance based upon current amplitude. *Looks for MV
So, updated this EQ. Make sure to grab the new schematic on the first post. it solves a lot of fl studio 12/ fl studio 20 bugs.
lalalandsynth
Post by lalalandsynth »
What are these FL bugs ? Can I expect my plugins to have problems running in FL ?
lalalandsynth wrote:What are these FL bugs ? Can I expect my plugins to have problems running in FL ?
sorry to leave You hanging, I had to take off.
But, it's when the flowstone fl studio version is tied to fl studio 12. Make sure it's un-installed from 12 or it stops flowstone plugs from being installed correctly.
I had registered My fl 12 before and then it suddenly stopped working. So, I re-installed and don't bother registering.
At least I can get 20 at My convenience. Any Negatives? Anyone?
Halon
Post by Halon »
Is this a clean eq or does it add color?
Halon wrote:Is this a clean eq or does it add color?
No colour, a smoothness though. I'm uploading the knob right now to the knobman gallery.
It's a bit heavy handed in the upper mids though. I might smooth that out in a small way.
