LA School Esquire Limiter
wlangfor@uoguelph.ca
Hi all, worked late into the night making this beast. It's not a Beta; But a working example to learn from. I plan on making a final version and I think there could be some optimizing.
max 3% CPU, I believe it could go down to 1.8?
Here are the images (click for full):
EDIT: New version 1.3 posted.
Changelog (1.3)
+ Better Logo
+ Named Presets
Changelog (1.2)
+ Better math (Now Using Ruby);
+ Peak calculation using slide and line primitive
+ Rough solution for attack and release now applied
click to enlarge:
Download Schematic
https://web.archive.org/web/20190501220351/http://dsprobotics.com/support/download/file.php?id=8686
Download Knob File (Now added to Knobman Gallery!)
https://www.g200kg.com/en/webknobman/gallery.php?m=p&p=1445
Download VST on KVR:
https://www.kvraudio.com/product/la-school-esquire-limiter-by-king-oz-records
Last edited by wlangfor@uoguelph.ca on Wed Sep 04, 2019 2:52 pm, edited 9 times in total.
My youtube channel: DSPplug
Re: LA School Esquire Limiter
Updated to 1.1; Changed the math so that the calculations are almost finite. I also removed some superfluous personal touches. This was made for a personal project.
(I'd removed some bass for asthetics, I may do the same but in a new way that is non-destructive).
BTW, I found a good reference in Ruby that allows these calculations for attack and release as follows:
(1-Math:E**(-1/(48000*250)));
And I wish to make a primitive derivative.
Please post a solution if You are aware of the translation. I will of course try to do that on My own otherwise.
This limiter is now added to VST4Free, it was made in association with them officially.
Here's the link to that:
http://vst4free.com/index.php?plug-ins=Mastering/Strip&l=0
and here's the link to the flowstoners.com website's section with the schematic for You to download :)
http://flowstoners.com/flowmates
Here's a new track I made with this fancy new limiter:
And I updated it so it represents the final track.
Last edited by wlangfor@uoguelph.ca on Wed May 08, 2019 4:20 pm, edited 1 time in total.
New Track I am working on with the Esquire:
Hi all, so I have updated this limiter so that it now has a slightly nicer design (more memorable) and it uses less CPU.
Here is a link to the KVR post (click image below):
It sounds a bit nicer now, a bit like the bands 2 EQ; I avoid using the attack for bassy kick drum samples though. I'll be adding an optional HP for such dilemmas.
