'Text View' ... but with pixs.
I've a question that I've not been able to find info on ... maybe someone can help
I've been including 'documentation' within my project that utilizes the 'TEXT VIEW' module. This has been really nice, as we are able to scroll through text much larger than the display area.
What I'd like to add is a similar 'scrolling' capability ... but for pictures. Whether they be PNG, GIF or maybe JPG [not real specific as yet] ... heck, it would be great to have a .PDF display capability.
My thought was to have images within this 'doc' section that could be used for examples or showing particular setup procedure. A type of built-in manual that includes more than just text.
Is this even possible ?? If so ... could anyone help me kick start
Thanks!
Thanks!
Re: 'Text View' ... but with pixs.
The same question here.
What is - is real PITA.
RJHollins wrote:A type of built-in manual that includes more than just text.
You can still make this happen with a nice "feel" to it....
Keep all your text in the text view, and load all your pics in separate module on a index.
Then just call the pic you need with scrollbar value.
Yyyym... could you post an example?
RJHollins wrote:could anyone help me kick start
Got your pm...it's not that easy is it mate.!! I got stuck lots of times thinking
about how to create an effective tutorial, that sits in the VST/Exe...
...seeing as you still stuck with an approach....hopefully this will help...
This module is set up like a book...
1 pic + 1 text array per page. use selector to flick through....
In order to make it work, you need to load your images and text,
as i have quickly just used the same bitmap and text for each page ...
- Tutorial Module.fsm
- (27.22 KiB) Downloaded 1045 times
Okay, and what about scrolling image within the text flow?
tester wrote:scrolling image within the text
Interesting technique...could you post an example?
You know, like you view/scroll an old html page, text, pix, text, pix...
tester wrote::mrgreen: I thought you were talking about something like this!
and needed a lot of work to make happen right....(can post if needed)
I went for trogs selector cause its so easy to modify(quickly), and also
cause RJ is stuck at the very start trying to create some sort of "framework" for
his idea. So i thought better to stay simple to start.
RJ can still get an 0-1 output from scrollbar, convert the range to the selector..
so as he scrolls from top to bottom he gets 12 pics + text...
Lots of ways to change the module.......
Hi biilv,
just got to dL the 'tutorial' a few moments ago ...
Nice, clear schematic layout ... and as a 'book/page' technique looks good !
Thanks for taking the time to do this !
I'll do some 'playing' tonite ...
If this becomes a 'launch' point for a 'text/pix 'type of GUI display would be very useful. I remember reading the community development of the 'text notepad' thread on the SM forum with much interest.
Still ... what you have 'tutorial-ed' brings 'text' & 'pix' in sync, and opens the door to include a type of manual within are app.
Nice
Nice
