Sine in ruby, output float.
borodadada
Re: Sine in ruby, output float.
it really depends on "what value do you want to get from the stream?"
- Frame to float.fsm
- (6.39 KiB) Downloaded 1094 times
borodadada
Need real-time, Complex number, real numbers and imaginary unit.
Don't understand what you mean. Stream data has no imaginary parts.
I guess it's about converted values into complex numbers. We had a lot of it on electronics looong time ago. Calculations made on complex numbers (a+ ib) refered to AC signals. @borodadada - better describe what you would like to get with it.
borodadada
guys, I can use any option, the amplitude values in real time, as in the picture I uploaded, need output with Ruby, in a numbers format.
borodadada
white noise...............
borodadada
ohh... done
code not working... because sound card is not active, DS OUT
def event i,v
a = v.to_array
output(a)
for some reason, flowstone die.....
def event i,v
a = v.to_array
output(a)
MyCo, tester
Thank you very much. We began to teach programming a week ago, We began to teach the sound of 10 years ago. and very frustrating when such simple topics so hard to understand
