A simple question for a three/way switch
Hi, I have a simple request. I have embeded two distortion units before a compressor and this is used as one module. so I want a switch that has an ''On Type 1'' - ''off'' - ''On Type 2'' off = bypassing the distortions and only using the compressor, so in other words this is a three way switch... can you help me ? I bet you can
I'm a rookie in ruby and Flowstone so excusee my ignorance :/
Re: A simple question for a three/way switch
Here is a simple example using a knob. You can change the knob bitmap to switch bitmap (having only 3 cells) and adjust the sensitivity parameter so it looks more "realistic".
- 3way.fsm
- (127.79 KiB) Downloaded 1054 times
WoW super thanks! that was fast! Could you also assist me in embeding two overdrives (with the 3way switch) to the default compressor/expander - also taking off that cutoof -atten module and replace it with the 2 ovedrives but it should be before the compression but after the compressor input~ and thats that really ~ making the midle bybass of distortions and the compressor be working clean
I hope this is not too much, I'm good at knowing what goes where but sinse still a rookie I have some trouble... :/
I can assist you, but I need a schematic to work on. So I can see what you want (preferred with comments in the schematic).
With "taking off that cutoof" you mean: removing the "Cutoff" knob? In this case, you would also loose some other controls (eg. Low/High, Low/Hi Meter). And btw. I don't have your 2 overdrives that you are refering to.
I'll give you a schematic later on today, its way easier than it sounds
I've simplified the schematic of the compressor a little bit, and added the overdrives.
I don't really like the default compressor... it's kind of way to complicated for what it does.
- Comp2.fsm
- (178.25 KiB) Downloaded 1099 times
Its not gona be like that, its all about having the right conections so I can just work on the ruby code
And so many super thanks man! Would you like to be in the beta tests when I'm done ?
