issue
issue
I found an issue I forgot about it. Last year I spent on this one a lot of time (it is a part of a larger design I was trying to fix), so I'm unable to think clearly on that one.
So here is the thing. (Buttons represent trigger flow in the design). Trigger1 sends a trigger that under normal circumstances goes freely. Trigger2 sends a trigger, that should go in specific order.
At that time I arranged it via timegate; while under low load it works fine - under higher load it becomes unpredictable (which is understandable). So I'd like to get rid of the time here, and fix it via trigger order. Please help.
- issue.fsm
- (4.65 KiB) Downloaded 829 times
Re: issue
...ooops, it looks that this was bigger issue in wider context. Need to spend some time on extracting it. Generally, as far I can see - the input node1 represents separate flow of triggers, independent from input node2, that why these things did not synced in order.
