double point slider
kortezzzz
double point slider
Post by kortezzzz »
I try to make a slider with 2 moving points that can cut the scale between 0 to 10 into 3 different areas. Both points should move forward and backward indeed and they should limit each other at the max and min points. For instance, if the right point is set to 6, the left point can't pass it. making it in green is a headache. Maybe Ruby can help here? Attached a picture for demonstration
https://imgur.com/cmSUqia
billv
Re: double point slider
Post by billv »
Here's a double slider I made a while back.
Hope it helps or gives you an idea of how to do it better. :|
Double slider_BV.fsm
(23.62 KiB) Downloaded 846 times
kortezzzz
Post by kortezzzz »
Boom! Awesome.Thanks a lot billv :)
It works nicely here. Any chance that each of the three zones gets it's own color, instead of transparent background in area A and C?
Nice stuff BillV 8-)
