HTTP POST questions
Posted: Mon May 27, 2013 10:17 pm
by Drnkhobo
Hey guys, im trying to mess around with this module (I know its on the forums here somewhere).
I have 3 questions maybe someone here has knowledge of:
1. What is the "ID" field for?
2. How can I send a message back from my server ? (see in the php '
echo $mail_sent ?' )
3. How can I create more key-value pairs to send data back and forth from my server ?
My PHP is non existent atm
Have a look at my example:
- HTTP.fsm
- (1.19 KiB) Downloaded 1029 times
Re: HTTP POST questions
Posted: Mon May 27, 2013 10:40 pm
by tester
There is an output node in this primitive "any returned data from the server".
My gues is, what goes back - depends on what you have on the server?
Anyway - what comes back from your server?
But there are IP based primitives (network client and network server), so probably you can use them with it. For example you send a request for IP, you get the IP, and then...
p.s.: my php is like my ruby...
Posted: Mon May 27, 2013 10:43 pm
by Drnkhobo
Yeah I saw that and inside the fsm is my php script im using.
Ill post it here:
<?php
//Capture data from $_POST array
$to = $_POST['to'];
//define the subject of the email
$subject = $_POST['subject'];
//define the message to be sent. Each line should be separated with \n
$message = $_POST['Message'];
$ID = $_POST['ID'];
//define the headers we want passed. Note that they are separated with \r\n
$headers = "From: noreply@myemail.com\r\nReply-To: noreply@myemail.com";
//send the email
$mail_sent = @mail( $to, $subject, $message, $headers );
//if the message is sent successfully print "Mail sent". Otherwise print "Mail failed"
echo $mail_sent ? "Mail sent" : "Mail failed";
see there . .
How do I get this to come back to the module?
