16 Input/Output Seqential Switch
Posted: Sat Nov 17, 2018 8:34 pm
Hello Gang,
This is pretty cool! Here is a simple 16 input and 16 output sequential switch. That is each output is selected sequentially, by the rate of the speed controls, course (F0-F8), and the fine speed knob. The buttons numbered 1,2,4,8 select either 16, 8, 4, or 2 outputs. All on (blue) is 16 , 8 off is 8, 4 off is 4, and 2 off is 2. All other combinations give odd counts, but also useful in some situations. Just play with it for awile and you will get the feel for it. The direction selector selects, up, down, up & down, in and out, or from the PM oscillator (Adds a little modulation to tones, just experiment). The LFO adds some frequency modulation (FM) to the speed oscillator for some more variations on patterns. Also the phase modulation (PM) oscillator does much the same as the FM modulator. Both of these oscillators can be removed of course if desired. Note that for the demo here I have selected 4 tones from four oscillators. You can though input just about anything, oscillators, filter outputs, lfo’s, adsr’s, and so on. They can also be in any combination as well, 16 oscillators, or 8 oscillators and 8 lfo’s, and so on. Well there you have. Please comment and if you have any suggestions for anything, PLEASE post.
Ok then enjoy, BobF…..
