Universal Knob, Slider, keyboard/touch entry/tooltip/info
- wlangfor@uoguelph.ca
So, there's a few products like Voxengo and Waves which have these nice modal windows when You type something in;
And I wanted to improve upon that a little and add touchpad support like Voxengo has.
I've drastically improved a version of Pali64's (The original post is below):
http://flowstone.co.uk/support/viewtopic.php?f=3&t=8314&sid=3f08a9ffdaa720df41c392f6c6ae9b0e
And I'd had a post where I spoke about possibilities, and where I wanted to take the idea.
Now that I'm actually posting complete examples I'm posting here:
http://flowstone.co.uk/support/viewtopic.php?f=4&t=13565&sid=3f08a9ffdaa720df41c392f6c6ae9b0e
So, there is logic built into this making sure You do not punch in a value that is too small or too large.
It also ensures there can only be one minus symbol (and that it is at the beginning - Currently a bug, showing up after a zero).
Furthermore, it's stayed under 24kb which is attractive. I intend to make it 21-22 for the final.
Anyways, without further delay, here it is:
[updated 10/26/2018]
Thanks,
Le Attol
Thanks,
Le Attol
- optimized image
- 5c2cd87db7178871724593.jpg (22.48 KiB) Viewed 10506 times
Last edited by wlangfor@uoguelph.ca on Wed Jan 02, 2019 4:28 pm, edited 2 times in total.
Re: Universal Knob, Slider, keyboard/touch entry/tooltip/inf
Updated to version 16, removed any error with dashes. Forgot about the decimals after the dash. This weekend I will finish the project and add keyboard input.
Here's what to expect:
+The keyboard input splash will show up first, there is a hand icon You press to get to the touchscreen version.
+ When You wish to open the touch screen, press the hand and the smaller popup will grow vertically, and once it has grown the buttons appear.
+ once You've inputted the number maybe I could have a green check; I just don't want the check to slow the process down by even a ms.
+ the touch screen input / keyboard input popup fades out
Here's what I plan:
+ Fade in and fade out tooltips (will make the fader faster) with icon selections; !, ? and so on.
+ Help tips with icon selection: ?, ! and so on
Here's what I plan:
