1x to 2x to 4x Sawtooth
BobF
Post by BobF »
Bobs1x2x4xSaw.fsm
(416.85 KiB) Downloaded 1040 times
Hello gang,
Back to some easy stuff! Here is a simple 1x to 2x to 4x Sawtooth multiplier/waveshaper module for your tool box. It can be used for your SUPER SAW's and also works as a wave shaper for sine, triangle, and parabola. A modulation input is also included.
I really like creating modules like this, I guess it's the challenge. The thought of how you can take this static wave shape and make it into another useful shape. Maybe some more as I can dream them up.
Comments always welcome!
Later then, BobF.....
adamszabo
Re: 1x to 2x to 4x Sawtooth
Post by adamszabo »
I like the concept, however its should be called Saw Octaver than a supersaw creator. In a supersaw the saws are the same pitch, only detuned slightly from each other, however this module add a saw on each octave. It could be interesting to multiply this thought and create an octaver supersaw. Now that would be interesting!
lalalandsynth
Post by lalalandsynth »
Testing this . :)
Halon
Post by Halon »
Thanks Bob :)
Interesting idea Bob (as always!). :ugeek:
The issue I saw and heard is with the green part used to switch over the selectors.
I think it would be much improved if all the control could be done in the audio stream. Then you could have LFO or even audio rate modulation without the clicking.
I like the range you get from using a sine wave especially, so I think it would be worth the effort.
BobF
Post by BobF »
Bobs2x4xSaw rev2.fsm
(914.64 KiB) Downloaded 1039 times
Hello gang,
Here is my best solution! Let me know what you think.
Thanks, Bob.
SO much better Bob! And done so quickly!
Well done mate, and thanks for sharing it.
Halon
Post by Halon »
Thanks again Bob :)
