Stream Trigger to Ruby or Graph Module
Posted: Wed Jun 13, 2018 8:00 pm
by aronb
Is there a way to trigger a Graph Module (1, 2, 4, or 8 input) from a stream (blue) signal? or trigger a Ruby module from a stream signal?
I am trying to accurately get a number samples into the graph module
at a specific trigger time, like at the edge of a stream signal, or when it goes high (or low)...
I realize that the will be some delay (100ms max?) but need to sample a number of signals at the same time so I can make a module to display the signals, much like a scope. I can put a Tic module on it but that is not sync'd up to anything. Even if I have a delay that is fine, as long as the group of channels is sampled simultaneously!
Here is a schematic that shows what I want to do, I just don't think its possible... at least with what I know
Thanks for any help and education,
Aron
Re: Stream Trigger to Ruby or Graph Module
Posted: Wed Jun 13, 2018 9:55 pm
I can offer this SyncScope. The graph will start at zero crossing (or any other threshold crossing you choose). Dunnno if that meets your goal.
Posted: Wed Jun 13, 2018 11:41 pm
by aronb
Martin,
Thank you for the quick reply AND a possible solution ! ! !
I just got home from work, and am busy reworking this in my schematic -
AND trying to figure out exactly how it works
and adding extra channels, if I am smart enough
I will post a reply soon!
Aron
Posted: Thu Jun 14, 2018 2:52 am
by aronb
Martin,
How on earth did you connect a Tic25 Module (Green) Output to a Mem2FA Module (Black Box) Input ? ! ? ! ?
- Magical Connection
- HOW.JPG (12.51 KiB) Viewed 18140 times
I am unable to complete this utter feat of magic
I need to connect the Tic25 to many Mem2FA Modules, if I do not the timing is slightly off per Mem2FA Module and thus the array output.
So far so good. I am just copying this magical connection for now...
Aron
Posted: Thu Jun 14, 2018 6:08 am
aronb wrote:How on earth did you connect a Tic25 Module (Green) Output to a Mem2FA Module (Black Box) Input ? ! ? ! ?
No magic there, just Shift-Ctrl
Posted: Thu Jun 14, 2018 7:46 am
martinvicanek wrote:aronb wrote:How on earth did you connect a Tic25 Module (Green) Output to a Mem2FA Module (Black Box) Input ? ! ? ! ?
I didn't know about this possibility!
Does this mean that
all the memory contents are re-read when the ticker supplies a trigger?
Posted: Thu Jun 14, 2018 11:11 am
Spogg wrote:martinvicanek wrote:aronb wrote:How on earth did you connect a Tic25 Module (Green) Output to a Mem2FA Module (Black Box) Input ? ! ? ! ?
Does this mean that
shift-ctrl is a general way to override restrictions, Flowstone makes for connections. That's why it must be used with caution. Not all forced connections will work and some might even crash Flowstone.
This is just a general comment, it does not answer your specific question, for which Martin will provide the answer.
Posted: Thu Jun 14, 2018 7:39 pm
Spogg wrote:Does this mean that all the memory contents are re-read when the ticker supplies a trigger?
Apparently so, yes.
I first thought that the black box connector provides the memory address and size and on the green side of the mem2FA prim you could access that data block as an array. But that does not seem to be how it works. You have to supply forward triggers at the black box input pin else it won't update. So it seems that data is actually copied into that float array.
This and the fact that you have to override FS' connector type matching to connect the ticker indicates that the mem2FA prim was designed for static use rather than the sync scope scenario. You might call it a hack, but I never had any problems with it.
Posted: Fri Jun 15, 2018 7:55 am
Thanks guys!
This might just help me in my current "research" (i.e. messing around) with granular effects. If so, this is a
very timely piece of information for me. If not, it's still really good to have this insight.
Now Martin and tulamide, please do me a great favour and tell me what else I don't know...
