Trouble with example[Solved]
alexalthauser
Post by alexalthauser »
Having trouble recreating the example from the manual. I enabled the mouse move messages on the mgui. The cursor changes when it moves in the window, but no coords are printed in the ruby console.
Last edited by alexalthauser on Tue Jan 22, 2013 11:00 pm, edited 1 time in total.
support
Re: Trouble with example
Post by support »
Looks like you have the V input as the second one down, the default is for the top one, otherwise you have to address it properly.
alexalthauser
Yes, I actually tried that right after I posted, it still doesn't output the coords from the window. However, I did hook it up to the mgui, and it returns coords when I mouse-over that module.
I think that the extra "external" MGUI may be confusing things.
The boolean "true" for the mouse_over has to be connected to the MGUI that's inside the display window - setting mouse-over true for one MGUI won't also set it for other ones, as they are being shown on different areas of the screen.
That got it working here, anyway - hope it helps.
alexalthauser
That was it. I thought it was an upper level switch, which would set the enable mouse moves to true for all components connected to it. Your way makes much more sense, though. Thank you.
