Bug: Smooth not shown in schematic
Walter Sommerfeld
Post by Walter Sommerfeld »
Smooth always active in FS
Only shows in compiled exe if its switched Off...
support
Re: Bug: Smooth not shown in schematic
Post by support »
Smoothing is indeed on by default. If you call the setSmoothingMode method on the View object then you can switch it off.
It sounds like you know that already though so I'm not sure if I've fully understood what the problem is here. Can you explain it in more detail?
Thanks.
Walter Sommerfeld
YUP - i'll try it again :idea:
Look at the selector part on my picture above... smooth is switched off - but no 'preview' until exported...
P.S: Smooth OFF not shown in schematic
support
Post by support »
As I understand it you have something that is supposed to display with smoothing off. In FS the smoothing is still applied but in the exported exe it works correctly - is that right?
Any chance you could email the schematic or just the bit showing the smoothing being switched off but displaying as smoothed?
Thanks
Walter Sommerfeld
I'm shure i've tested the TOP Gui Layer...
...maybe also a reload changed the smooth state view :?:
Now after hide/show and copy/paste it into an empty schematic only the 2nd chain layer shows it smoothed... :o
Smooth=Off.fsm
(1.23 KiB) Downloaded 1113 times
support
Post by support »
Thanks for posting the schematic.
I see what the problem is now. The MGUI does set the smoothing on by default so if you want to change it you need to insert the Smooth component after the MGUI. If you do that it should work fine.
Walter Sommerfeld
Thanks...
works now...
btw: Components Manual (Chapter 2) Page number is wrong 4 Smooth etc...
4 our wishlist: Links from Component Index page directly to their Listing explanation
